Hi!
I have a simple question regarding the Time range controls.
Can I disable the view of some of them on my dashboards?
e.g - disable “relative time ranges” and enable “Absolute time range” or even better disable view of some of them by my customization?
I can see I can disable all the times by going to settings->hide time picker but I do want the time picker , just times as I pick that can be picked according to my queries and data on the db.
Many thanks
Keren
