V7.3.6: When panel in "View", then modifed time range settings are applied for current panel only, not for dashboard
just wanted to comment behaviour described in topic. In Previous versions when a panel was in “View” mode and time range setting were changed, then those new time range settings were applied to all panels on dashboard. ow when resetting fomr View mode, this panel keeps newly applied time range, all other panels show previous time range.
Regards,
-jayvee.
Indeed I tried on the playground, and it’s the same result (server requests - 1h, other panel - 6h) :
I think this is a bug, can you submit an issue to GitHub to be reviewed.
Thank you
Issue created: #30246
