Time navigation buttons
I am trying to recreate the energy consumption bar chart from Home Assistant and I am particularly interested in the time selection / navigation bar in the upper right corner.
Having these quick selection buttons is much more comfortable than the default time selector in Grafana.
What makes it even more complicated is that I want to have these buttons per chart and not per dashboard.
Any ideas?
hi @massaquah :wave:
This post may find more constructive feedback from the community in our Github discussions’ page. :slightly_smiling_face:
I had the same problem and built a couple of buttons using javascript.
I did this on version 9.5, but using the text visualization create a couple buttons and script to modify the url, in my case I wanted it to change by the day.
Here’s what I did:
Modify the grafana config file for scripts to be ran under:
disable_sanitize_html = true
and restart.
Then using the text button put this code in, modifying it to your own website and times.
<button onclick="incrementValue()">Go Back</button>
<button onclick="decreaseValue()">Go Forward</button>
<script>
  function incrementValue()
    var value_to_add;
    var regex_1 = /(?:https:\/\/yourwebsite\/d\/)\w{8}-\w{4}\-\w{4}\-\w{4}\-\w{12}\/\S*\?(?:orgId=)\S{2}(?:from=now-)/;
    var regex_2 = /(?:https:\/\/yourwebsite\/d\/)\w{8}-\w{4}\-\w{4}\-\w{4}\-\w{12}\/\S*\?(?:orgId=)\S{2}(?:from=now-)\S*(?:to=now-)/;
    var regex_3 = /(?:https:\/\/yourwebsite\/d\/)\w{8}-\w{4}\-\w{4}\-\w{4}\-\w{12}\/\S*\?(?:orgId=)/;
    var url = String(window.location.href);
    var url_split = url.match(regex_3);
    var location_1 = regex_1.exec(url);
    var location_2 = regex_2.exec(url);
    if(location_1 != null)
    //get and change the number
      value_to_add = Number(url.at(location_1[0].length))+1;
    else
      value_to_add = 1;
    new_url = url_split[0] + "&from=now-" + value_to_add +"d%2Fd&to=now-"+value_to_add +"d%2Fd";
    window.location.href = new_url;
  function decreaseValue()
    var value_to_add;
      value_to_add = Number(url.at(location_1[0].length))-1;
    else
      value_to_add = 0;
    if(value_to_add == 0)
       new_url = url_split[0] + "&from=now%2Fd&to=now%2Fd";
    else
</script>
