Grafana v11.3, Windows 11 -
I want to post the fields as seen in Image 1 attached. However, what was sent to the database is Image 2. Image 3 is my server code and Image 4 displays the logs for my node js server. Data matches except for the time only. What seems to be the problem here?
Everything works except that the time does not coincide so I singled out everything -
What happened?
8:00 inputted in grafana becomes ‘2025-01-09T00:00:38.265Z’ in payload
Time inputted in Grafana’s business form panel to match the payload to be sent to my database. -
Attached is my custom code for POST request of the grafana panel -
Request TypeError: Cannot read properties of null (reading ‘value’) -
N/A
