Time labels overlapping in XY Graphs
Hi Grafanistas,
I know that the XY Chart is still in beta. I have too many labels displayed on the X axis which is time. They overlap.
I tried to find a setting in Overrides to reduce the number of labels.
(Zooming in and out helps but different charts in the display have different zoom requirements and of course this is not the way to solve the issue).
Anyone have a solution to avoid this.
Thank you for any solution to the issue as screen grabbed below.
Warm wishes
Eric
Hey everyone! Anyone found a solution for this? I have the same problem!
Try to change X-axis minimum spacing
