XY Chart / Scatter Plot XY axis individual label customization
    v9.4.3 in a docker container
    I am trying to put separate custom labels on the x and y axis in the xy chart visualization (scatter plot?)
    I am trying to use the GUI
  • What happened?
    There is only one input field for an “axis” label and when I put in a custom label name, it changes the labels of both axes
    That i can customize both axis labels
You can specify labels for Y-Axis using overrides.
Thank you, I didn’t expect to solve this with overrides.
For those who struggle to find how to do it, here is what I did for my case:
Tab Overrides > Add field override > Field with name > {field which is used as y-Axis} > Add override property > Axis > Label
