Time duration calculation between rows
I am using the last Grafana version with Infinity plug in.
It acquires data from an API that build a table in Grafana with timestamp and value information.
Changing the visualization to “state timeline” the chart shows in the tooltip the value of “duration” which calculates the values between two sequential timestamps (between rows).
I have been trying to calculate same value using “add field from calculation” without success since all the options just do operations between colums and not between rows.
I need to do this calculation in Grafana since API server application does not have resource to do it.
What would be the suggestions?
Would be possible to extract the duration values from “state timeline” chart?
Atttached the table in Grafana.
Welcome @acinvx
Can you share your Infinity query (and ideally the URL that you are getting the data from) so that one can see what the data looks like in tabular form? I would think you can calculation the durations using the parser tools or UQL.
Hi @grant2. Thanks for your reply.
Transformation options would be best way since we are working in an initiative of “no code” integration between Grafana and vNode Gateway, a software that make available industrial realtime and historical data throught its API. Until now I have avoided to do queries using JSONata and UQL to make easier for common industrial users work with both softwares.
The software API endpoint is:
[localhost:3003/tag?cmd=history&path=/Random/Int1&start=2025-03-02T11:50:00.000&end=2025-03-02T11:51:00.000&options.mode=raw] and the JSON answer (example) is:
  "request": {
    "tag": "/Random/Int1",
    "start": 1740927000000,
    "end": 1740927060000,
    "options": {
      "remoteNode": null,
      "mode": "raw",
      "method": null,
      "interval": null,
      "deadband": null,
      "invalidAsNull": true,
      "limit": null
  "data": [
      1740927000000,
      119,
      192,
      2
      1740927002986,
      37,
      192
      1740927008002,
      57,
      192
      1740927013020,
      23,
      192
      1740927018034,
      71,
      192
      1740927023046,
      92,
      192
      1740927028064,
      70,
      192
      1740927033075,
      17,
      192
      1740927038091,
      43,
      192
      1740927043107,
      41,
      192
      1740927048121,
      121,
      192
      1740927053141,
      95,
      192
      1740927058155,
      51,
      192
I am using Frontend parser, table format and selecting the columns through:
[0] as timestamp format as Time (UNIX ms)
[1] as value format as string
Hi @acinvx
I put your sample JSON into play.grafana.org here. Not sure what “Frontend parser” is. Can you complete the rest of your query parameters and save?
Hi @grant2.
I am having an issue to log in that I am trying to solve. For now I am sending a print screen of the configuration:
Frontend parser is the same of Default in the Parser setting.
Below the real data I am using in the project (same of previous one but instead of numerical values I have strings that describes production line status):
  "request": {
    "tag": "/SimuProducao/L1",
    "start": 1742136600000,
    "end": 1742158260000,
    "options": {
      "remoteNode": null,
      "mode": "raw",
      "method": null,
      "interval": null,
      "deadband": null,
      "limit": null
  "data": [
      1742136600000,
      "Parada Programada - CIP (Lavagem)",
      192,
      2
      1742150727131,
      "Em Operação - Envase",
      192
      1742151001069,
      "Em Operação - Preparação de Matéria-Prima",
      192
      1742151301015,
      "Em Operação - Filtragem",
      192
      1742151601023,
      "Em Operação - Rotulagem",
      192
      1742151901021,
      192
      1742152201011,
      "Em Operação - Pasteurização",
      192
      1742152501025,
      192
      1742152801009,
      "Parada Programada - Manutenção Preventiva",
      192
      1742153101009,
      192
      1742153401011,
      "Em Operação - Embalagem",
      192
      1742153701011,
      192
      1742154001017,
      192
      1742154301023,
      "Parada Não Planejada - Ajuste de Máquina",
      192
      1742154601019,
      192
      1742154901027,
      192
      1742155201020,
      192
      1742155501010,
      192
      1742155801023,
      192
      1742156101011,
      192
      1742156401010,
      192
      1742156701023,
      192
      1742157001024,
      "Em Operação - Extração do Suco",
      192
      1742157301012,
      192
      1742157601025,
      192
so in this data that you have provided which rows are you trying to base your calculation on?
1&2, 3&4. etc? What if there is odd number of rows what would 5 before compared to if there is no row 6?
Using the json you posted please demonstrate the result you expect as json.
if you dont want to use UQL and jsonata then you will most probably not be able to solve it.
Here is the data in Play:
so for example for Em Operação - Pasteurização there are 4 rows. how will that be calculated, which values will be used to calculate duration?
@grant2
Timestamp values are in a sequence and each value represents the “start” of production status. What I need to calculate is the difference between each sequential rows (for example: timestamp/row2 - timestamp/row1 = duration line2; timestamp/row3 - timestamp/row2 = duration line3). The end target is to calculate individual and total operation and stoppage times to use in KPIs calculations (MTBF, MTTR, OEE, etc.).
Just as a note, “state timeline” chart does exactly what I need when make available the “duration” information. The problem is that information is not available to use.
I saw that you put my data in the https://play.grafana.org/ but did not configure the columns with [0] and [1] in order to have filtered table.
Hope this information clarify a little bit more the challenge.
Thank you!
@yosiasz I think this answer also respond your question. See below the “state timeline” example with the data provided:
Please provide the above as it is a bit more confusing to be honest
Done. I will have a look later when I have more time, but as @yosiasz stated, UQL and jsonata may be needed.
Sorry if my english is not too clear.
I already have the data organized from a query in the API and in this way I do not need to query the data from the API source, just do the calculation throught transformations based in the table that I am including here (same from first post). the JSON data is the same I posted in the previous replies:
What will the desired final data look like
Como serão os dados finais desejados?
What I need is an additional column in the table with duration time [What I need to calculate is the difference between each sequential rows (for example: timestamp/row2 - timestamp/row1 = duration line2; timestamp/row3 - timestamp/row2 = duration line3).]
we get that :slight_smile: now provide another sample data as json or as csv of what the final data will look like when the calculation is done.
entendemos isso :slight_smile: agora forneça outros dados de amostra como json ou como csv de como os dados finais ficarão quando o cálculo for feito.
Here is:
“timestamp”: 1742151144229,
“value”: “Em Operação - Preparação de Matéria-Prima”,
“duration”: 156786
“timestamp”: 1742151301015,
“value”: “Em Operação - Filtragem”,
“duration”: 300008
“timestamp”: 1742151601023,
“value”: “Em Operação - Rotulagem”,
“duration”: 299998
“timestamp”: 1742151901021,
“duration”: 299990
“timestamp”: 1742152201011,
“value”: “Em Operação - Pasteurização”,
“duration”: 300014
“timestamp”: 1742152501025,
“duration”: 299984
“timestamp”: 1742152801009,
“value”: “Parada Programada - Manutenção Preventiva”,
“duration”: 300000
“timestamp”: 1742153101009,
“duration”: 300002
“timestamp”: 1742153401011,
“value”: “Em Operação - Embalagem”,
“duration”: 300000
“timestamp”: 1742153701011,
“duration”: 300006
“timestamp”: 1742154001017,
“value”: “Em Operação - Envase”,
“duration”: 300006
“timestamp”: 1742154301023,
“value”: “Parada Não Planejada - Ajuste de Máquina”,
“duration”: 299996
“timestamp”: 1742154601019,
“duration”: null
@yosiasz and @grant2,
I will continue studying the alternatives for a “no code” approach but for now I decided to do it with JSONata and already have the data organized in a way that I can do the calculations needed.
Thank you very much for your support looking this subject.
Here is the JSONata expression I used as information for people interested how I solved this part of the project:
$map($$.data, function($v, $i, $a) {
($i < $count($a) - 1) ? {
“Status”: $v[1],
“Start”: $v[0],
“Stop”: $a[$i+1][0],
“Duration”: $a[$i+1][0] - $v[0]
} : null
This will create 4 columns with status, start, stop and duration and put the timestamps received in a sequence as start and stop values. Also, the stop value is the start value for each new row.
Nice work @acinvx
I put your JSONata expression into the dashboard and still am not getting it. Do I have the syntax correct? Maybe another “)”?
this might help to get the juices flowing.
$.data.{
    'metric' : $fromMillis($[0]),
    'time': $[1],
    'value': $[2]
OP is not very thorough in his posts. each post is more confusing than the previous.
@yosiasz I do not want to disrespect your experience and knowledge as Grafana champion but I think that your comments are not correct. Everything is very clear in my answers if you read them.
In my last comment I informed the solution I found using JSONata and that worked for this moment.
So, there is nothing for your different comments about confusion.
If you have specific questions please let me know and I will be happy to clarify.
