Time duration calculation between rows
no offense taken, you are welcome to speak freely. so your issue has been solved by jsonata?
see this https://try.jsonata.org/YYpEA3W8M, your jsonata is not working for us.
Hi @grant2
Thank you for testing the JSONata expression that I used.
I am using the backend parser option instead UQL and getting the data directly from my API.
I did some tests in your dashboard and it seems an additional problem is the JSON inline convertion to data frame. Notice that JSON answer that I provided is the same I am getting from Postman. I also tried to upload a response file from Postman without success.
Here is a print of the configuration:
