What Grafana version and what operating system are you using? 9.5.3
What are you trying to achieve? Creating a time series graph for CPU utilization
How are you trying to achieve it? I have the data that is retrieved from API using Infinity plugin.
What happened? Time is shown as 1970-01-20 13:42:43 for EPOCH value 1687363762
What did you expect to happen? Should display the correct year, month & date along with time.
I am retrieving data from the API source with the following UQL query:
parse-json
| jsonata "($.*).({'CPU USAGE': cpu.totalUsage, 'LAST ACTIVE AT':was_active_at, 'LAST DEVICE INFO REFRESH AT':device_info_refreshed_at})"
I get 3 columns in the table and the values are in EPOCH
I added a transformation to the field and then selected “Convert Field Type” and the Type as “Time” and Format as “Unix”. But I get the time as 1970-01-20 13:42:43
How can I get a proper datetime value? I have seen solutions where they ask to scale the value by 1000 but that is not available for this plugin source.
