What Grafana version and what operating system are you using? Grafana Cloud
What are you trying to achieve? Epoch time (ms) difference between time labels (t2 - t1) in separate panel queries (frames?)
How are you trying to achieve it? We think we might need the Concatenate Fields expression but there is almost certainly a better way to do it by creating a label in LogQL
What happened? We get no apparent usable output from the concat expression
What did you expect to happen? We hoped the labels would be available for the delta
Can you copy/paste the configuration(s) that you are having problems with? Below
Did you receive any errors in the Grafana UI or in related logs? No
Did you follow any online instructions? If so, what is the URL? Transformation functions | Grafana documentation
Sample logs / LogQL
t1
Dec 01 02:33:31 60100-33333 traffic[4819]: [traffic_app.cpp:1083] TrafficApp::trigger_callback:(trigger = A) happens at T1 [1669862011643]
{application=“traffic”}
|= trigger_callback
| pattern <_> _T1_ [<t1>]
t2
Dec 01 05:33:42 60100-33333 traffic[38779]: [radar_controller.cpp:468] RadarController::radar_read_thread()[1669872822841], get radar interrupt [115660] [5488]ago T2 [1669872817353]
|= get radar interrupt |= _T2_
| pattern <_>, get radar interrupt [<_>] [<_ms_>]ago _T2_ [<t2>]
Also we have a related question regarding the epoch resolution i.e. we’re using milliseconds but it appears the lowest conversion resolution Grafana supports is seconds apart from the implicit tNs timer.
I can’t find the documentation but I definitely remember reading that - can repost this last as another thread if required.
Many TiAs and Merry Christmas ![]()
