Threshold for "From now" in new Stat panel
Hi!
Cannot figure out how to setup threshold for new Stat panel. What should I do if I want the panel to become red when value is more that 10 minutes (“минуты назад” means “minutes ago”)?
P.S. On screenshot I tried 10 minutes in milliseconds.
P.P.S. It seems that one should specify unix timestamp there…
Hi @albertugatu,
have you found a solution for this?
I also tried to set up a threshold for a stat panel while getting a unix timestamp but it doesnt work for.
Thanks in advance.
Unfortunately I don’t remember. This happened a long time ago.
Hi @grafanajul,
Can you please try to reproduce this same issue on https://play.grafana.org/ and then share the dashboard link so that we can view it?
Thanks
