Hey everbody,
i´ve got some measurements from different sources and want to visualize the time between the last measurement and the present. At the Moment i am using the singlestat panel selecting the measurment and its last Date. As Unit i used “From now” and it shows (what i wanted) the days since the last measurement. For example “3 days ago” or “2 weeks ago”.
Now i would like to color the panel red in case the measurement is longer ago than 7 days. But the thresholds-option does not work with days, hours and so on… i think its calculating the decimal number of the date and references to this decimal number…
Anybody got an idea how to color the passed time in green, yellow or red ?
Thanks a lot
