Hi, guys
I have used grafana version 10.1.5, which is connected to InfluxDB. TRUE is input as ‘True’ when using Variable in Influxdb Query Wizard to output a metrics corresponding to the boolean type True value to the graph. And the graph does not print and the no data comes out.
Steps
Create a variable to output the value matched to the boolean type true
After choosing “build_result”::field in Query Wizard, Select a variable " created in STEP1.
No data comes out in the graph panel.
Click the pencil icon to check the Query statement. The value is as shown below. as you can see, there is a single quotation mark.
Query : WHERE (“build_result”::field = ‘true’) -
When I delete a small quotes( from ‘true’ to true), the graphs are output normally.
Query : WHERE (“build_result”::field = true)
Variables must enter query statements without single quotes to function normally.
Is this a graphana error? How can I make the boolean values appear in the graph panel using Variable?
Any ideas? Much appreciated…
Grafana Version 10.1.5 / OS : Ubuntu 20.04 -
To print influxdb data to graph panel properly -
- Create a variable to output the value matched to the boolean type true
- After choosing “build_result”::field in Query Wizard, Select a variable " created in STEP1.
What happened?
no data comes out -
influxdb data should be printed in graph panel -
