I have data with the values true and false (influxdb). I want to display these values with cursor.
I don’t get any value there, the graph refers to the “true” data as value 1.
Thanks
Thanks
Can you explain the above in greater detail?
I get “null”, I want to see the real value, in this case it should be “true”
It appears your menu is different from the one that I shared. I am using Grafana v8.3.3. Which version are you using?
I upgrade to your version and it works,
Thanks
