Hi all,
- using Grafana 11.4 with Prometheus 2.54
What are you trying to achieve? I followed this (Jenkins agent monitoring with Prometheus | by Rudolf Horváth | Tresorit Engineering | Medium) instructions and set-up a jenkins job - that create a plan text html file for Prometheus to consume and provide Jenkins agents health status - endpoint setup and refresh is as expected
sample line from the file (replaced agent details)
jenkins_agent_is_connected{agent_name=“”, node_labels=“docker AllWindows “, ip=””} 1
I’ve configured a job in prometheus.yml that should collect the data - as instructed in the doc- job_name: ‘jenkins-agents’
scrape_interval: 5m
scheme: https
basic_auth:
username:
password:
static_configs:
- targets: [‘’]
metrics_path: ‘/Jenkins_Agents_Prometheus/lastSuccessfulBuild/artifact/prometheus’
I expected to see the relevant matrixes in Grafana, I see the Job listed under Jobs label but I don’t see the matrixes from the file, instead I see the below matrixes (not found in the file).
any suggestions?
