The Dashboard does not correctly display all the data from the SQL query
    Grafana v10.4.1 in docker
    I need the classes to be displayed on my dashboard
    through this query :
    SELECT fecha,
    array_to_string(array_agg(clase), ‘,’) AS clases,
    COUNT(cantidad) AS cantidad_total
    FROM preconsulta2
    GROUP BY fecha
    ORDER BY fecha ASC
  • What happened?
    It only brings me the result of the count
    NO
    NO
Which column is date time?
SELECT fecha as time,
array_to_string(array_agg(clase), ‘,’) AS metric,
COUNT(cantidad) AS value
FROM preconsulta2
GROUP BY fecha
ORDER BY fecha ASC
The fecha column is the one that has time and date in timestamp (postgres) in the following format: YYYY-MM-DD HH:MM:SS.SSS
then try this
       array_to_string(array_agg(clase), ',') AS metric,
  FROM preconsulta2
 GROUP BY fecha
 ORDER BY fecha ASC
It keeps bringing me only the count value and what I really need is for it to bring the classes counted separately. I never had this problem before, I have been using grafana for several years.
looks like some regression bug. try this transformation
Works! thank you
el formato de mis datos en postgres es YYYY-MM-DD HH:MM:SS.SSS
