Hi guys
i need to graph a bar graph in grafana. i have this kind of data
hour status | count
|2023-10-30 04:00:00| 10 | 3|
|2023-10-30 04:00:00| 209| 4|
|2023-10-30 04:00:00| 310 | 1|
so i want this data to be grouped by hour but i do not want to have multiple times i just want one 4:00 then all the status and count under that 4:00
I used a couple of transformations, i grouped your data by date and time, then i extracted the fields, then i hid the original fields, and stacked them:
thanks a lot. what does your query code look like because i am using code
my code i want to change to look like the one you just posted
SELECT DATE_TRUNC(‘hour’, updated_at) AS hour, status,
COUNT(*) AS count
FROM orders
where DATE_TRUNC(‘hour’, updated_at) = ‘2023-10-30 04:00:00’
GROUP BY DATE_TRUNC(‘hour’, updated_at), status
ORDER BY hour;
can you help me modify it
I used a csv file containing the data you provided:
