Text position in gauges in version > 13.0
    13.0.1
    Reposition the text below the gauge, as in previous versions.
    Display small-sized gauges, but with readable text.
  • What happened?
    In the current version, the text is positioned in the middle of the gauge.
    The previous version’s behavior, where the text was located below the gauge.
    V12.3
    V13.0.1
    V12.3
    V13.0.1
    No
    No
I tested this on Grafana 13.0.1 and there is currently no option to position text below the gauge in the new Gauge panel. I went through all available options
Style Circle / Arc → text stays inside in both
Text mode Auto, Value, Value and name → text stays inside in all modes
Orientation Auto, Horizontal, Vertical → no effect on text position
This is a change in Grafana 13 redesigned Gauge panel. The old Gauge placed text below the arc, the new one always places it inside.
1 → Make the panel bigger Since text is now inside the gauge, larger panels give enough room for readable text without overlap or cutoff.
2 → Reduce text size In the Gauge section → Text size → set Value to a smaller number (12 or 14) so it fits inside without being cut off on small panels.
3 → Downgrade to Grafana 12 The old behavior is preserved in v12.
