I’m configuring my 1st Dashboard. I have some issue positioning 3D Gauges:
As you can see, the gauge is not centerd to Panel and below space is too much.
Is there a way to reduce below sapce and center the Gauge on tha Panel?
Marco
Marco
I don’t have an answer for you, but I have seen odd behavior with these gauges not displaying properly or displaying multiple gauges with the same data in one panel.
Here’s the GitHub issue for this: https://github.com/briangann/grafana-gauge-panel/issues/11
