11.3.0 OSS on Docker
Previously working layout:
By keeping the same configuration as in 11.2.0
What happened?
Did an upgrade to 11.3.0 from 11.2.0 and since then the Gauge and Stats panel are having very weird layout display issues.
The layout to remain the same as in 11.2.0
No errors in logs.
