Text panel: Printing selected time range including time zone
    v11.0.0
    Print the selected time range in the selected time zone with format YYYY-MM-DD HH::mm::ss TZ
            <div style="font-size: 16px;">
                Selected Time Range : ${__from:date:YYYY-MM-DD HH\:mm\:ss} to ${__to:date:YYYY-MM-DD HH\:mm\:ss}
            </div>
  • What happened?
    The selected time is printed, but it is in local time.
    Have the selected time printed in the set time zone. All of our data is stored in UTC, that is how we want to view it, that is the time zone set for the dashboard, and that is how we want it printed in the text panel
    N/A
    No errors.
    No
I think this is basically a duplicate of: Can I get ${__from:date} in UTC using the format I want?
