Grafana v10.1.5 (849c612fcb) -
Display current time in user selected timezone in the grafana panel title -
using $__to and $__from methods -
What happened?
above method display it in browser time instead of user selected timezone -
display time in user selected timezone -
Last Updated Time ${__to:date:DD-MM-YYYY HH:mm} -
No errors -
