Text/Html panel is not displaying embedded iframe in Grafana
Grafana 7.5.2.
I created new panel with Text visualation as HTML.
<html>
<head></head>
<body>
<iframe src=“http://www.google.com” width = 670 height = 510 ></iframe>
</body>
</html>
It should display google page in panel.
  • What happened?
Not showing iframe remote page in panel. I changed below configurations but still not displaying page. It gives page not found 404 Error.
I changed /usr/share/grafana/conf/defaults.ini , also changed grafana.ini and restarted grafana server but stillk it show below panel.
enable_alpha = true
disable_sanitize_html = true
enable_alpha = true
allow_embedding = true
cookie_samesite = none
enable_alpha = true
enable_alpha = true
Page not found
404 Error
Chances you are on the page you are looking for.
0%
Sorry for the inconvenience
Please go back to your home dashboard and try again.
The disable_sanitize_html setting is working otherwise you would just see the html as text and not a 404. The 404 is almost certainly happening due to a CORS error.
Google actually doesn’t allow iframing by anyone outside of Google so it won’t work (see this example on StackOverflow). If you change the src to a site that allows iframing then it should work.
Here is an example:
<html>
<head></head>
<body>
<iframe src="https://bbc.com" width="670" height="510"></iframe>
</body>
</html>
