I am using Tempo. Sometimes it has autocomplete and it works well. Other times, it does not work at all or works but barely. Any suggestions on how to make it work reliably? Thanks.
Hi, all auto-complete comes from recent received data in the ingesters. This is controlled by complete_block_timeout which defaults to 15 minutes. This means that if no data is received for the last 15 minutes then auto-complete will no longer return any values. This is a common scenario in clusters that receive variable workloads or testing.
If this doesn’t explain it then we can dig further and look for errors and configuration issues.
Hello. Thank you for your two replies.
I definitely use braces. The timeout is 15 minutes. I just sent traces to it and tried again. Still no autocomplete.
Here are two screenshots. The first shows the autocomplete. The other shows the traces and their attributes. Also, I tried { span. } then pressed control-space after typing ‘.’, Again, no useful autocomplete.
Maybe I have something wrong with the docker compose files. Anything come to mind to look at? I will include those as well.
Thank you very much.
Kareem
docker-compose.yaml:
version: “3”
services:
loki:
image: grafana/loki:latest
command: “-config.file=/etc/loki/config.yaml”
ports:
- 3101:3100
volumes:
- ./loki.yaml:/etc/loki/config.yaml
depends_on:
- minio
promtail:
image: grafana/promtail:latest
command: -config.file=/etc/promtail/config.yaml
volumes:
- ./promtail.yaml:/etc/promtail/config.yaml
- /var/run/docker.sock:/var/run/docker.sock
depends_on:
- loki
minio:
image: minio/minio:latest
command: server /data
volumes:
- ./data/minio-data:/data
environment: - MINIO_ROOT_USER=grafana
- MINIO_ROOT_PASSWORD=grafana_secret
ports: - “9000:9000”
- “9001:9001”
entrypoint: - sh
- -euc
- mkdir -p /data/tempo /data/loki-data /data/loki-ruler && /opt/bin/minio server /data --console-address ‘:9001’
To eventually offload to Tempo…
tempo:
image: grafana/tempo:latest
command: [ “-config.file=/etc/tempo.yaml” ]
volumes:
- ./tempo.yaml:/etc/tempo.yaml
- ./tempo-data:/tmp/tempo
ports: - “3200:3200” # tempo
- “4317:4317” # otlp grpc
- “4318:4318” # otlp http
depends_on: - minio
And put them in an OTEL collector pipeline…
otel-collector:
image: otel/opentelemetry-collector:latest
command: [ “–config=/etc/otel-collector.yaml” ]
volumes:
- ./otel-collector.yaml:/etc/otel-collector.yaml
depends_on: - tempo
prometheus:
image: prom/prometheus:latest
command:
- –config.file=/etc/prometheus.yaml
- –web.enable-remote-write-receiver
- –enable-feature=exemplar-storage
volumes: - ./prometheus.yaml:/etc/prometheus.yaml
ports: - “9090:9090”
grafana:
image: grafana/grafana:latest
volumes:
- ./grafana-datasources.yaml:/etc/grafana/provisioning/datasources/datasources.yaml
- ./grafana-plugins-bundled:/usr/share/grafana/plugins-bundled
- ./grafana-data:/var/lib/grafana
environment: - GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_DISABLE_LOGIN_FORM=true
- GF_FEATURE_TOGGLES_ENABLE=traceqlEditor
- GF_LOG_MODE=console
- GF_LOG_LEVEL=info
ports: - “3000:3000”
volumes:
- type: bind
source: ./minio-data
target: /data
bind:
propagation: shared
tempo.yaml
server:
http_listen_port: 3200
distributor:
receivers: # this configuration will listen on all ports and protocols that tempo is capable of.
jaeger: # the receives all come from the OpenTelemetry collector. more configuration information can
protocols: # be found there: https://github.com/open-telemetry/opentelemetry-collector/tree/main/receiver
thrift_http: #
grpc: # for a production deployment you should only enable the receivers you need!
thrift_binary:
thrift_compact:
zipkin:
otlp:
protocols:
http:
grpc:
opencensus:
ingester:
amount of time a trace must be idle before flushing it to the wal.
(default: 10s)
trace_idle_period: 20s
how often to sweep all tenants and move traces from live → wal → completed blocks.
(default: 10s)
flush_check_period: 3s
Traces are written to blocks. Blocks are cut when they reach a size or length of time.
Traces are first stored in the Write Ahead Log (WAL).
After a threshold, traces are compacted to a block and written to the backend storage.
maximum size of a block before cutting it
(default: 524288000 = 500MB)
max_block_bytes: 524288000
maximum length of time before cutting a block
(default: 30m)
max_block_duration: 30m
duration to keep blocks in the ingester after they have been flushed
(default: 15m)
complete_block_timeout: 15m
Flush all traces to backend when ingester is stopped
flush_all_on_shutdown: false
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
Query Frontend configuration block
query_frontend:
search:
query_backend_after and query_ingesters_until together control where the query-frontend searches for traces.
Time ranges before query_ingesters_until will be searched in the ingesters only.
Time ranges after query_backend_after will be searched in the backend/object storage only.
Time ranges from query_backend_after through query_ingesters_until will be queried from both locations.
query_backend_after must be less than or equal to query_ingesters_until.
(default: 15m)
query_backend_after: 15m
(default: 30m)
query_ingesters_until: 30m
metrics_generator:
registry:
external_labels:
source: tempo
cluster: docker-compose
storage:
path: /tmp/tempo/generator/wal
remote_write:
- url: http://prometheus:9090/api/v1/write
send_exemplars: true
compactor:
compaction:
Optional. Duration to keep blocks. Default is 14 days (336h).
block_retention: 336h
Optional. Duration to keep blocks that have been compacted elsewhere. Default is 1h.
compacted_block_retention: 48h
storage:
trace:
backend: s3 # backend configuration to use
wal:
path: /tmp/tempo/wal # where to store the the wal locally
s3:
bucket: tempo # how to store data in s3
endpoint: minio:9000
access_key: grafana
secret_key: grafana_secret
insecure: true
overrides:
metrics_generator_processors: [service-graphs, span-metrics] # enables metrics generator
Thank you for the very detailed information. Don’t see anything obviously missing from the configuration.
Here are a few more ideas to explore:
Is Tempo or Grafana logging any errors?
Can you check which versions of Grafana and Tempo you are running? Instead of
latest
maybe try fixed versions likegrafana/tempo:2.2.2
andgrafana/grafana:10.1.1
Can you try calling the Tempo auto-complete API directly? We can start with /api/search/tags which returns the list of attribute names. It doesn’t require any parameters. Before calling it, first verify there is data stored in the ingester area which is
/tmp/tempo/wal
based on the configuration above.
Thank you very much for the help.
- No errors.
- Used the suggested versions. No autocomplete works!! So very nice.
Again, thank you very much.
