I’ve seen a fair few people trying to get this working, and it seems like the docs are missing an example for people to work from, so hopefully that can be the example.
Example prior post: How enable Service Graph with Tempo
I’m facing the same issue as others, where I believe everything is configured and enabled, but there are no span metrics being written into prometheus, but no idea how to debug it and get it working.
Here’s how everything is set up right now:
docker-compose.yml
version: "3.8"
services:
loki:
image: grafana/loki:2.9.3
command: -config.file=/etc/loki/local-config.yaml
ports:
- "3100:3100"
prometheus:
image: prom/prometheus:v2.45.0
ports:
- "9090:9090"
volumes:
- ./etc/prometheus:/workspace
command:
- --config.file=/workspace/prometheus.yml
- --enable-feature=remote-write-receiver
- --enable-feature=exemplar-storage
depends_on:
- loki
tempo:
image: grafana/tempo:2.3.1
command:
- "--target=all"
- "--storage.trace.backend=local"
- "--storage.trace.local.path=/var/tempo"
- "--auth.enabled=false"
- "--config.file=/etc/tempo/tempo.yaml"
ports:
- "14250:14250"
depends_on:
- loki
volumes:
- ./etc/tempo:/etc/tempo
grafana:
image: grafana/grafana:10.2.2
ports:
- "3000:3000"
environment:
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_DISABLE_LOGIN_FORM=true
volumes:
- ./etc/grafana/:/etc/grafana/provisioning/datasources
- ./etc/dashboards.yaml:/etc/grafana/provisioning/dashboards/dashboards.yaml
- ./etc/dashboards:/etc/grafana/dashboards
depends_on:
- loki
- prometheus
Traces in other services (which I’ve removed from the compose for simplicity) are being received and show up fine in the trace explorer in tempo, but the service graph has its normal “This isnt configured” and going to prometheus and looking for the span metrics shows nothing is published.
My tempo.yaml is:
metrics_generator:
registry:
external_labels:
source: tempo
cluster: docker-compose
storage:
path: /tmp/tempo/generator/wal
remote_write:
- url: http://prometheus:9090/api/v1/write
send_exemplars: true
overrides:
defaults:
metrics_generator:
processors: [service-graphs, span-metrics]
And my grafana datasource.yaml is:
# config file version
apiVersion: 1
# list of datasources that should be deleted from the database
deleteDatasources:
- name: Prometheus
orgId: 1
# list of datasources to insert/update depending
# what's available in the database
datasources:
# <string, required> name of the datasource. Required
- uid: prometheus
orgId: 1
type: prometheus
typeName: Prometheus
access: proxy
password: ''
user: ''
database: ''
basicAuth: false
isDefault: true
jsonData:
exemplarTraceIdDestinations:
- datasourceUid: tempo
httpMethod: POST
readOnly: false
editable: true
- uid: tempo
orgId: 1
type: tempo
typeName: Tempo
access: proxy
url: http://tempo
password: ''
user: ''
database: ''
basicAuth: false
isDefault: false
jsonData:
serviceMap:
datasourceUid: 'prometheus'
nodeGraph:
enabled: true
search:
hide: false
lokiSearch:
datasourceUid: loki
tracesToLogs:
datasourceUid: loki
filterBySpanID: false
filterByTraceID: true
mapTagNamesEnabled: false
tags:
- service
readOnly: false
editable: true
- uid: loki
orgId: 1
type: loki
typeName: Loki
access: proxy
url: http://loki:3100
password: ''
user: ''
database: ''
basicAuth: false
isDefault: false
jsonData:
derivedFields:
# enableNameMatcher: true # swap when released: https://github.com/grafana/grafana/pull/76162
matcherRegex: 'TraceID.*: "(\w+)"'
url: $${__value.raw}
readOnly: false
editable: true
Traces coming through fine:
Service graph isnt:
And the expected metrics in prometheus don’t exist:
I’m unsure what else to try. The tempo.yaml seems to explicitly turn on the service-graphs and span-metrics processors in the default setting, and prometheus has its remote write feature enabled. Does anyone have any idea what could be going wrong?
