Traces to metric is not happening , required help here to achieve this
BELOW IS SCREENSHOT EXPECTATION (refer: Service graph view | Grafana Tempo documentation)
Current Situation
Here is the current config file of tempo
server:
http_listen_port: 3200
distributor:
receivers: # this configuration will listen on all ports and protocols that tempo is capable of.
jaeger: # the receives all come from the OpenTelemetry collector. more configuration information can
protocols: # be found there: https://github.com/open-telemetry/opentelemetry-collector/tree/main/receiver
thrift_http: #
grpc: # for a production deployment you should only enable the receivers you need!
thrift_binary:
thrift_compact:
zipkin:
otlp:
protocols:
http:
grpc:
opencensus:
ingester:
max_block_duration: 5m # cut the headblock when this much time passes. this is being set for demo purposes and should probably be left alone normally
compactor:
compaction: # overall Tempo trace retention. set for demo purposes
metrics_generator:
registry:
external_labels:
source: tempo
cluster: docker-compose
storage:
path: /tmp/tempo/generator/wal
remote_write:
- url: http://prometheus:9090/api/v1/write
send_exemplars: true
storage:
trace:
backend: s3 # backend configuration to use
wal:
path: /tmp/tempo/wal # where to store the the wal locally
s3:
bucket: tempo-grafana # how to store data in s3
endpoint: s3-ap-south-1.amazonaws.com
insecure: true
overrides:
metrics_generator_processors: [service-graphs, span-metrics] # enables metrics generator```
can you check if we have following metrics coming into your configured prom datasource
to use service graphs, you need to enable metrics generator, can you double check and make sure that metrics geneator is enablde. see config steps here
if you are using Grafana less then 9.0.4, service graphs were hidden under the feature toggle tempoServiceGraph
, you need to enable that.
Thanks for you reply @surajsidh ,
Let me put my use case here so that you can give me a proper solution
I am instrumenting node js app with opentelemetry auto instrumentation
Here is the node js code
const sdk = new opentelemetry.NodeSDK({
traceExporter: new OTLPTraceExporter({
// optional - default url is http://localhost:4318/v1/traces
url: "http://localhost:4317/v1/traces",
// optional - collection of custom headers to be sent with each request, empty by default
headers: {},
metricReader: new PeriodicExportingMetricReader({
exporter: new OTLPMetricExporter({
url: 'http://localhost:4317/v1/metrics', // url is optional and can be omitted - default is http://localhost:4318/v1/metrics
headers: {}, // an optional object containing custom headers to be sent with each request
concurrencyLimit: 1, // an optional limit on pending requests
instrumentations: [getNodeAutoInstrumentations()],
sdk.start();
Here is docker-compose file :
version: "3"
services:
#And put them in an OTEL collector pipeline...
otel-collector:
image: otel/opentelemetry-collector:0.25.0
ports:
- "6831:6831"
- "4317:4317"
- "4318:4318"
- "9464:9464"
volumes:
- ./otel-collector.yaml:/config/otel-collector.yaml
command:
- --config=/config/otel-collector.yaml
dummy-server:
build: ./src
ports:
- "4000:4000"
- "80:80"
depends_on:
- tempo
- loki
loki:
image: grafana/loki
ports:
- "3100:3100"
minio:
image: minio/minio:latest
environment:
- MINIO_ACCESS_KEY=tempo
- MINIO_SECRET_KEY=supersecret
ports:
- "9001:9001"
entrypoint:
- sh
- -euc
- mkdir -p /data/tempo && /opt/bin/minio server /data --console-address ':9001'
tempo:
image: grafana/tempo:latest
command: [ "-config.file=/etc/tempo.yaml" ]
volumes:
- ./shared/tempo.yaml:/etc/tempo.yaml
- ./tempo-data:/tmp/tempo
ports:
- "3200:3200" # tempo
depends_on:
- minio
prometheus:
image: prom/prometheus:latest
command:
- --config.file=/etc/prometheus.yaml
- --web.enable-remote-write-receiver
- --enable-feature=exemplar-storage
volumes:
- ./shared/prometheus.yaml:/etc/prometheus.yaml
ports:
- "9090:9090"
grafana:
image: grafana/grafana:9.3.2
volumes:
- ./shared/grafana-datasources.yaml:/etc/grafana/provisioning/datasources/datasources.yaml
environment:
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_DISABLE_LOGIN_FORM=true
- GF_FEATURE_TOGGLES_ENABLE=traceqlEditor
ports:
- "3000:3000"
Otel config file :
receivers:
otlp:
protocols:
grpc:
exporters:
otlp:
endpoint: tempo:4317
prometheus:
endpoint: "0.0.0.0:9464"
service:
pipelines:
traces:
receivers: [otlp]
exporters: [otlp]
metrics:
receivers: [otlp]
exporters: [prometheus]
Tempo Config file :
server:
distributor:
thrift_http: #
thrift_binary:
thrift_compact:
zipkin:
otlp:
protocols:
http:
grpc:
opencensus:
ingester:
compactor:
compaction:
block_retention: 1h # overall Tempo trace retention. set for demo purposes
metrics_generator:
registry:
external_labels:
source: tempo
storage:
remote_write:
storage:
trace:
wal:
s3:
bucket: tempo # how to store data in s3
endpoint: minio:9000
access_key: tempo
secret_key: supersecret
insecure: true
overrides:
Promethues config file :
global:
scrape_interval: 15s
evaluation_interval: 15s
scrape_configs:
- job_name: ‘prometheus’
static_configs:
- targets: [ ‘localhost:9090’ ]
- job_name: ‘tempo’
static_configs:
- targets: [ ‘tempo:3200’ ]
- job_name: ‘otel-collector’
static_configs:
- targets: [‘otel-collector:9464’]
Hi @sagarmeadepu , can you see if you have traces_spanmetrics_latency
, traces_spanmetrics_calls_total
, and traces_spanmetrics_size_total
in your Promethues. If these metrics are not coming in then, it means that either they are not being generated or not being scraped.
unfortunettly it’s hard for me to replicate this setup without investing significanet time.
I would recommend checking our out demo repo: GitHub - grafana/intro-to-mlt: Introduction to Metrics, Logs and Traces session companion code..
You can run it locally with docker-compose, play around with it and see how it’s configured. Hopefully, this demo will help to trace down your issue
If issue still presists, can you share logs from tempo, Promethues, and your application.
Yes these metrics are not available ,
As you have suggest let me play with the GitHub example Thanks
Or As i have setup already available we can get into call to check this one
@surajsidh ,
In this github example " GitHub - grafana/intro-to-mlt: Introduction to Metrics, Logs, and Traces session companion code.."
The application is exposing metrics in ‘/metrics’ URL , In my scenario i would like to export them to open telemetry with “http://localhost:4317/v1/metrics” url
I have tried changing some of the settings but still getting error “{“stack”:“Error: PeriodicExportingMetricReader: metrics export failed (error Error: 12 UNIMPLEMENTED: unknown service opentelemetry.proto.collector.metrics.v1.MetricsService)\n at doExport (/Users/kamlakara/Documents/grafana_tempo/s3_new/src/node_modules/@opentelemetry/sdk-metrics/build/src/export/PeriodicExportingMetricReader.js:75:23)\n at process._tickCallback (internal/process/next_tick.js:68:7)”,“message”:“PeriodicExportingMetricReader: metrics export failed (error Error: 12 UNIMPLEMENTED: unknown service opentelemetry.proto.collector.metrics.v1.MetricsService)”,“name”:“Error”}”.
looks like this error is coming from opentelemetry/sdk-metrics
, I would recommend looking at OTEL SDK docs, or asking in OTEL community
