Tempo receive traces but doesnt send it to S3 storage backend
    I am using a Linux OS with an Ubuntu Distro and Grafana version 10.2.0
    I am trying to send traces from tempo to my S3 storage backend
    I configure opentelemetry collector in my cluster to collect traces from my Django application and then send them to Grafana Tempo
  • What happened?
    I was able to view the traces in tempo. Infact I can even visualize them using Grafana
    But, the traces are not in my storage backend. I can’t view the traces in my storage backend
    This is my grafana tempoconfig `distributor:
    receivers:
    otlp:
    protocols:
    grpc:
    http:
ingester:
trace:
block:
flush_block_size: 2
max_block_duration: 5s
storage:
trace:
backend: s3
s3:
bucket:
endpoint: https://objectstore.lon1.civo.com/tempo
access_key: 7HGAFDNFY3O8508FW2QW
secret_key: lO7mAi6Y6CuEKVwzxQ1hQhY5HycuT1BHjOAW79
