Hi All,
Please I need advice on fixing these errors.
I’m noticing these errors in grafana dashboard when importing these jason files (source # flux2/manifests/monitoring/monitoring-config/dashboards at main · fluxcd/flux2 · GitHub)
Template variable service failed e.replace is not a function
Templating [namespace]
Error updating options: parse error at char 1: vector selector must contain label matchers or metric name
Grafana version is
- Grafana v7.3.7 (1e261642f4)
Thanks.
welcome to the forum, @reppakayala
those json files imported without error for me. I was using Grafana 8.5.5
Thank you @mattabrams.
Actually, I am facing this issue and due to the reason, it’s not working.
Any idea/ hint to fix this issue, please?
Helm upgrade failed: failed to create resource: Internal error occurred: failed calling webhook “prometheusrulemutate.monitoring.coreos.com”: Post “https://prometheus-kube-prometheus-operator.metrics.svc:443/admission-prometheusrules/mutate?timeout=10s”: no endpoints available for service “prometheus-kube-prometheus-operator”
All these issues are fixed.
The grafana dashboards were working fine not sure suddenly stopped working.
How do troubleshoot it to find out the root cause?.
Rgds,
Ravindar
what @yosiasz said. also try increasing the verbosity of the Grafana server logs to debug
and note any errors. For printing to console, set the console logs to debug
as well.
@reppakayala were you able to find the cause of the issue?
This can happen if there is a parsing error or invalid characters in data links or template variables, especially in older versions of Grafana.
Other things to check if you run into this:
- Are you on a current version of grafana?
- Is the dashboard compatible with your version? Sometimes community-contributed dashboards can be out of sync with the version of grafana you have.
- Use Chrome Developer Tools or similar and check the console when the error occurs - often there are hints about what resource is causing the issue.
- What do you see in the query inspector response?
