Grafana version: v8.5.0 -
Trying to create a dashboard to monitor several apis who are logging to elastic -
Apis can be differentiated using their request endpoint i would like to have a template variable which can store a regex to match these endpoints and then use the variable in the lucene query for different panels -
What happened?
Did not see any data with template variable, without template variable and direct regex in query it works -
Data should be populated with variable storing regex -
No -
No
