Using Regex/Substring of a Template Variable and adding it to a Query Elasticsearch db
Grafana Version - Grafana v10.0.2 (b2bbe10fbc)
Operating System - Windows 11
  • What are you trying to achieve - I want to use Regex / Substring operation on a Template Variable called $SerialID
  • How are you trying to achieve it - 1. I created a TextBox Template variable with the name SerialID which takes a 16 character user input. 2. The database source is Elasticsearch logs. 3. I need to extract substring from index 5-12 of the 16 character $SerialID value, and then use it to query a field called “id”.
    This is what I have -
    And this is something I am trying to achieve - I want either substring or regex here
  • What happened?
    If I have a look at the query inspector - It does not recognize the variable when substring is used -
    But it recognizes its value normally without the substring operation -
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - No errors by Grafana - just the fact that I am not able to do a basic regex on a template variable and would love to know how to write a query properly for ElasticSearch DB
    I also saw something like this -Elasticsearch template variables | Grafana documentation
    But I haven’t quite understood how it works or how to form my query based on the explanation above.
Oh yes - its the same thread -
The regex would be something like this -
/^.{5}(.{4})(.{2})(.{4})*/ out of which I want Group 1 and Group 3 and concatenate them.
Do you happen to know what the query would look like?
PS: Here is the link to what I am trying to achieve. regex101: build, test, and debug regex
if same thread can we close this one? it helps to keep things neat and tidy
