I’d like to use a multi-value template variable to link to another dashboard, but the format needs to be something like &var-tempvar=a&var-tempvar=b&var-tempvar=c, however {tempvar} returns {a,b,c}. There doesn't seem to be a template variable format that will allow this extrapolation. If I use {__all_variables} it goes through just fine, however, so I’m not sure why using one of the template variables can’t respond in the same way. I’m using version 7.1.5.
Related topics
| Topic | Replies | Views | Activity | |
| Template Variable Formatting Options - missing URL format | 0 | 1576 | August 10, 2020 | |
| How to write a panel link if it need to contain a template variable which is Multi-value type? | 3 | 534 | September 3, 2025 | |
| Drill down / detail link | 6 | 7327 | November 25, 2019 | |
| Using of template variables in Dashboard List for querying | 0 | 1984 | January 17, 2019 | |
| Variables and dashboard link | 1 | 922 | July 26, 2021 |
