Table visualization is not displaying all the columns returned by the SQL query
I have created a Table panel and set up the Non-Time Series, Custom (Repository) query as follows:
SELECT
a.event_id,
b.target_type,
b.target_name,
a.severity,
a.creation_date,
a.last_updated_date,
a.reported_state
FROM
sysman.mgmt$events_latest a,
sysman.mgmt$agents_monitoring_targets b
WHERE
a.target_guid = b.target_guid
AND a.open_status = 1
AND a.closed_date > sysdate
AND a.severity = ‘Fatal’
order by b.target_type, b.target_name;
The visualization is set to Table.
Issue: All the table columns are created but the EVENT_ID column has no data in it. The same SQL run manually shows that the Event_ID is in fact pupulated with data.
Why would this one column not display data?
what does the data in Table View show
Table view also shows an empty column.
This is an Oracle Database. The Event_ID field has a data_type of “RAW”. Not sure what that means.
maybe not a data type supported in the oracle datasource? maybe convert it using CAST_TO_VARCHAR2 ?
Also do you need to see that field in table? not sure how much meaning it has in case it is internal identity like guid
I need to pass it as a query string parm in a data link to another dashboard
most probably it looks something like this when looked at from within Oracle?
8135869AECF44FB280A04033888FD518
Yes it does.
Using rawtohex seems to fix the display issue
SELECT
rawtohex(a.event_id) EVENT_ID,
b.target_type,
b.target_name,
a.severity,
a.creation_date,
a.reported_state
FROM
WHERE
I can now pass it as a query parm
/d/f15q_vpNk/event-detail?orgId=1&var-event_id=2EAAAAEA27DBD648E0630C414E0A0B0C
Now I need to convert it back to raw to use it in the detail query
Select
b.target_type,
b.target_name,
a.msg
From
sysman.mgmt$events a,
where
AND event_id = $event_id;
so it does not work as is when used in the query?
It works when used explicitly but not as a variable. I am attempting to determine that the variable actually has the value in it.
Select
b.target_type,
b.target_name,
a.msg
From
where
AND event_id = hextoraw($event_id);
is not working but
Select
b.target_type,
b.target_name,
a.msg
From
where
AND event_id = hextoraw(‘2EAAAAEA27DBD648E0630C414E0A0B0C’);
does work
Got it
Select
b.target_type,
b.target_name,
a.msg
From
where
AND event_id = hextoraw(‘$event_id’);
I had to enclose the variable in ’ ’
hextoraw('$event_id');
