Hello guys,
I’m currently working on a gantt chart. I have insert my data using SQL query but the results are not showing on the panel.
Here’s my SQL Query:
SELECT
lightColour,
DATEDIFF(s, timeStarted, GETDATE()) as StartTime,
DATEDIFF(s, timeEnded, GETDATE()) as EndTime
FROM tb_Events
Here’s the table view of my data:
The data is Formatted as “Table”.
Am I missing something?
Thank you in advance for any help.
Thank you thank you,
Kevin.
Hello Mr Yosiasz,
Thank you very much for the quick response.
May I know what’s the number column for ?
Here’s the value of my table.
Hello Mr Kevin
Please post your data not as an image but inline csv text?
id,lightID, state,timeStarted,timeEnded,remark,lightColour
1,1,1,2022-06-30 10:08:20.000,
etc
Sure thing.
Here’s the data inline
ID,lightID,state,timeStarted,timeEnded,remark,lightColour
1,1,1,2022-06-30 10:08:20.000,2022-06-30 10:38:20.000,NULL,Red
6,1,1,2022-06-30 11:28:20.000,2022-06-30 11:48:20.000,NULL,Red
7,2,2,2022-06-30 10:38:20.000,2022-06-30 11:28:20.000,NULL,Green
8,3,1,2022-06-30 11:48:20.000,2022-06-30 12:18:20.000,NULL,Blue
9,3,1,2022-06-30 11:48:20.000,2022-06-30 12:18:20.000,NULL,Blue
Yes sir! This is exactly what I needed ! Can you please share the code please. Thank you thank you !
Thank you very much for the help kind sir ! I have successfully got it to work. You are my saviour ! TQ TQ.
