do somebody know how i can change the size of the text in a table?
The problem has occurred since the last update. with the change to 9.5.2, the text no longer fits. Before the text was displayed correctly and there was no line break.
In addition, I can not understand the formatting.
Because in other columns with the same character length this does not happen.
for example see image:
Thanks
