I am using the 9.2.0 version of Grafana and I want to increase the text size of the values inside my table. I didn’t see any option to do it.
Can anybody help me with this issue? Thanks in advance.
Probably need to do this with some custom CSS
This approach might be a way to do it?
Wouldn’t that be an easy feature to add? Since you can already change the color of the text, size shoudn’t be a problem I woul’d figure.
I was kind of suprised that this not possible.
Could you share to me how to custom CSS of table
Agreed! Kind of makes Grafana tables useless on a large TV style wallboard which is a real good application for it otherwise.
