hi Guys,
i have Table and under uptime stands stopped and ok.
how can i hide values ok ?
that one only see stopped ?
many greetings
SELECT “status” AS “uptime” FROM “system” WHERE (“object” = ‘qemu’) AND $timeFilter GROUP BY “host” LIMIT 1
hi Guys,
many greetings
Hi
If you are using Grafana 7.4+, try to exclude it using ‘Filter data by value’ transformation.
Here you can see the details:
Your filter is wrong!
Try as follow.
Match: Is equal
Value: 0
rest is the same.
Filter type: Exclude
Conditions: Match all
Value: 1 (the actual value, not the text you changed)
