I configure my alloy to receive syslog messages like this:
logging {
level = "debug"
format = "logfmt"
loki.source.syslog "syslog" {
listener {
address = "0.0.0.0:1514"
protocol = "udp"
use_rfc5424_message = true
forward_to = [loki.write.grafana_loki.receiver]
loki.write "grafana_loki" {
endpoint {
url = "http://loki:3100/loki/api/v1/push"
I’m using docker for running Grafana Alloy like this:
alloy:
image: grafana/alloy:latest
pull_policy: always
profiles: [ "alloy" ]
restart: on-failure
volumes:
- ./config/alloy:/etc/alloy
command:
- run
- /etc/alloy/config.alloy
- --storage.path=/var/lib/alloy/data
- --server.http.listen-addr=0.0.0.0:12345
- --stability.level=experimental # Enable all functionality
ports:
- "12345:12345"
- "1514:1514/udp"
depends_on:
- syslog-ng
When I runned, the log show this message:
ts=2024-08-16T04:40:10.231800215Z level=warn msg="failed to read packets" component_path=/ component_id=loki.source.syslog.syslog addr=<nil> err="read udp [::]:1514: use of closed network connection"
ts=2024-08-16T04:40:10.231865966Z level=info msg="syslog server shutting down" component_path=/ component_id=loki.source.syslog.syslog protocol=udp err="context canceled"
At docker container, I not see port 1514 listen:
root@e9fdccabba7a:/# netstat -na
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 127.0.0.11:34685 0.0.0.0:* LISTEN
tcp 0 0 172.21.0.3:48548 172.21.0.2:3100 ESTABLISHED
tcp6 0 0 :::12345 :::* LISTEN
udp 0 0 127.0.0.11:60361 0.0.0.0:*
udp6 0 0 :::1514 :::*
How to solve this?
Tks
