Alloy - Do not send Alloy logs to syslog
I have installed some Alloy agents recently, and have an issue with the syslog.
All Alloy logs have been written to the default syslog on Linux.
I have made a basic log configuration for Alloy, but despite this the logs continue to being written to the host syslog.
Here is the Alloy logging part in my config.alloy file :
logging {
    level  = "debug"
    format = "logfmt"
    write_to = [loki.process.alloy_logs.receiver]
loki.process "alloy_logs" {
    forward_to = [loki.relabel.global_label.receiver]
    stage.static_labels {
        values = {
            service_name = "alloy",
Thanks for your help !
It seems that I’ve found the issue : my journald.conf indicates to follows all logs to SysLog (by default).
I will check that and modify this post in “solved” if all works as intended.
The issue is now solved : I give up on the “debug” level of the logs.
When setting it to “info” the logs stop spamming my SysLog. Simplest way, but efficient !
But, if someone have a solution to set a log file for all Alloy logs, I will be glad.
maybe this? how are you runnning alloy? systemd or a container?
logging {
  level  = "info"
  format = "logfmt"
where does alloy write to
Alloy is running with systemd,
I see that I can redirect the log output if I run it in single binary, with a declaration in /etc/systemd/
Since I put “level = info” my Syslog is less spammed, I think that will be ok like this.
