I have an Alloy server listening for syslog logs:
loki.source.syslog "remote_syslog" {
forward_to = [loki.write.grafana_loki.receiver]
relabel_rules = loki.relabel.remote_syslog.rules
listener {
address = "0.0.0.0:1514"
tls_config {
cert_file = "/etc/pki/realms/domain/default.crt"
key_file = "/etc/pki/realms/domain/default.key"
And my servers have Rsyslog configured to send logs to Alloy:
cat /etc/rsyslog.d/00forward-logs-loki.conf
*.* action(
type="omfwd"
target="loki.example.com"
port="1514"
protocol="tcp"
Template="RSYSLOG_SyslogProtocol23Format"
TCP_Framing="octet-counted"
queue.type="linkedList"
queue.size="10000"
action.resumeRetryCount="100"
streamDriver="gtls"
streamDriverMode="1"
streamDriverAuthMode="x509/name"
streamDriverPermittedPeers="*.example.com"
It kinda works, but quite often it’s losing logs, and Rsyslog complains:
rsyslogd: omfwd: TCPSendBuf error -2078, destruct TCP Connection to loki.example.com:1514 [v8.2312.0 try https://www.rsyslog.com/e/2078 ]
action 'action-0-builtin:omfwd' suspended (module 'builtin:omfwd'), retry 0. There should be messages before this one giving the reason for suspension. [v8.2312.0 try https://www.rsyslog.com/e/2007 ]
action 'action-0-builtin:omfwd' resumed (module 'builtin:omfwd') [v8.2312.0 try https://www.rsyslog.com/e/2359 ]
Servers are, at the same time, also sending their logs to a central Rsyslog server syslog.example.com (which is actually only a CNAME to the same host than loki.example.com), and this flow is not losing any log, so I feel the problem is coming from Alloy.
Am I doing something wrong?
