Synthetic Monitoring Agent minimum requirements
I can’t find information about the minimum requirements for set an instance with a Synthetic Monitoring Agent, in this case, running the docker image.
The questions originated by the need to run this container in AWS Fargate, Google Cloud Run and Azure Container Instances, I need to create the service and configure it with the minimum requirements, but working correctly.
Can someone help me bringing me that information please?
It depends on the number of executed tests. Generaly, those tests are not memory, cpu intensive, so you can start with minimal sizing. Then monitor mem/cpu usage and scale when you will be reaching cpu/mem limits.
