v10.1.2 on LXC container Proxmox 7.4.3 -
I have 3 different solar power sources and want to total the amount of generated power. Futhermore I want to display the SOC in the same chart. -
Using a time series panel with power on the left axis and SOC on the right axis. I have all values in the diagramm and I want to display all of them. But I want to add a curve with the total amount of solar power. With a transformation from the existing values I add a field from calculation (calculation = total). -
What happened?
This leads to two issues:
First: SOC is calculated into the total and there seems no way to exclude it. The error is manageable but not ideal.
Second, even worse: I see regular power spikes on the total signal, that aren’t there in input signals, therefor it must come from the calculation. I assume it is due to an asynchronous feed of data among the different sources. But how can I fix this?
SOC to be excluded from the operation and signal looking good without spikes.
