Ok, so it’s like that. Can you use Reduce transformation with Series to rows mode (I think Last calculation should be fine for your case). Then use Group by transformation.
so in the case of the data you are showing in that screen shot it corresponds to Series 37 in the original sample data you posted? The closer to real data as is on your side you show the easier and quicker to get to a probable solution.
When you post
Series 37= 1
Series 20 = 2
Series 22 = 1
Series 22 = 3
Series 22 = 1
Series 43 = 10
we might make assumptions
So in the case of 37 which one would be the “last value” as there are dups, unless my eyes are failing me
We can see that there are multiple series with the same name. Some are CPU utilization 1 and others are CPU utilization 2. The same applies to the initial dataset I provided as an example.
The data is not presented in a table with a column for each series. In the table view, we see that the data is separated by a selection box.
Ok, so we’re almost there. Now after you have used group by transformation, change the option of the stat visualization (on the right side). Look for Value Options section, then under “Show” instead of default “Calculate” pick “All values”
