Hi
I created a panel and 2 queries.
Each query returns a single value.
My goal is to display a single value, which is the sum of both values.
Please advise.
Thanks
Shay
Hi
Please advise.
Thanks
Shay
Hi @shaynaveh,
What version of Grafana are you using? You should check out transformations.
UPDATE:
I would now use the add new field from calculation transformation to solve this. Probably many different ways to get here…
Here is a dashboard example on our public sandbox:
https://play.grafana.org/d/7t-PJFlnk/reduce-2-series-to-single-value?orgId=1
old answer:
Here is an example I made with some dummy data representing two queries, where each query returns a single value. I then used two transformations to merge the values and sum them:
Hey,
Sum of two queries seems to be buggy with dynamic Dashboard
regards,
Tiki_
UPDATE:
I would now use the `add new field from calculation to solve this rather than the chained reduce transformations in the video. Probably many different ways to get here…
