I’m developing a service Flow Metrics Statistic on Thither.Direct .
You can view information on the service
There is already a user dashboard(graphs) on Thither.Direct.
While, if a user want to(or already) work with Grafana.
It will be great to have suggestion and recommendations for either it is better to have it as
- a data-source plug-in (req. and data structure conversion) - more optimal for data-transfer rate
or should
- the service to be ready as a data-source. - more optimal for dev. friendly
At the moment, there is a Python based library to work with the service, pushing and getting data
https://github.com/kashirin-alex/Thither.Direct-client-libraries/tree/master/python
So, the main question, remains Is it preferred to have a datasource-plugin (NodeJS buildin) or a stand alone data-source service such as simple_python_datasource.py
I can have a test/demo account ready for Grafana demonstrations, in-case, for Grafana Dev. and plugin showcase and for any other case, I’ll be glad to consider.
Thank You,
Kashirin Alex
