Grafana connection to remote DB
Hi all,
I am working on a Trenitalia project to connect Grafana to a service called PdMS: “Predictive Maintenance and Service” that is a solution powered by SAP HANA in-memory technology based on SAP Hana DB.
I am just trying to connect Grafana to Hana DB to catch data for a performance monitoring.
I installed and activated a generic simplejason datasource plugin into my localhosted installation of Grafana.
Then I installed and activated the Panel plugin Plot.ly
Now I am waiting for a deployment of a package into the XSA Server.
Do I need to install a specific datasourse plugin developed for the Trenitalia client needs or can I use a generic one?
Kind regards,
Tommaso
You will likely need a specific data source developed specifically to support the Trenitalia HTTP api.
