I have to 500+ windows laptops to monitor using Grafana 12.1.1 and influx db 2.7.9 in oracle linux 8.10 and installed telegraf plugin 1.36.4 in windows laptops. Suggest a grafana dashboard that is readable or give an overview of the dashboard how its should be displayed
Depends on what you want the dashboard(s) to tell you
Is it by department
Is it by threshold of certain metrics (disk above 340 gb of 400)
Showing 500+ might be a bit over the top and hard to parse.
Etc
Hi, I need System uptime, CPU,Memory and disk utilization, Battery status(Good,weak,Fair),Network usage. As of now the above are needed for checking we can use alerts in future process
Do you want to see all system in one list? Just the ones below thresholds? Do you want to be able to filter the list?
Do you want to be able to dive down into a detailed dashboard?
Many options.
