Total Laptops: import “influxdata/influxdb/schema”
schema.tagValues(
bucket: “telegraf”,
tag: “host”,
start: -90d
|> group()
|> count(column: “_value”)
Laptops Online: import “influxdata/influxdb/schema”
schema.tagValues(
bucket: “telegraf”,
tag: “host”,
start: -5m
|> distinct()
|> count()
Laptops Offline: import “influxdata/influxdb/schema”
Get ONLINE hosts in last 5 minutes as array
onlineHosts = schema.tagValues(
bucket: "telegraf",
tag: "host",
start: -5m
|> findColumn(fn: (key) => true, column: “_value”)
Get TOTAL hosts (last 90 days) and filter offline
schema.tagValues(
bucket: "telegraf",
tag: "host",
start: -90d
|> filter(fn: (r) => not contains(value: r._value, set: onlineHosts))
|> distinct()
|> count()
Laptop Battery: from(bucket: “telegraf”)
|> filter(fn: (r) =>
r.\_measurement == "windows_battery" and
r.\_field == "condition_grade_code"
|> last()
// Map numeric code to readable status
|> map(fn: (r) => ({
r with status:
if r.\_value == 2 then "Good"
else if r.\_value == 1 then "Fair"
else "Poor"
// Group by status and count laptops
|> group(columns: [“status”])
|> count()
// IMPORTANT: force one series per status
|> map(fn: (r) => ({
\_measurement: "battery_summary",
\_field: r.status,
\_value: float(v: r.\_value)
|> group(columns: [“_field”])
CPU: from(bucket: “telegraf”)
|> range(start: -15m)
|> filter(fn: (r) =>
r.\_measurement == "cpu" and
r.\_field == "usage_system" and
r.cpu == "cpu-total"
|> group(columns: [“host”])
|> last()
|> map(fn: (r) => ({
r with
usage_category:
if r.\_value <= 10.0 then "0-10%"
else if r.\_value <= 20.0 then "11-20%"
else if r.\_value <= 30.0 then "21-30%"
else if r.\_value <= 40.0 then "31-40%"
else if r.\_value <= 50.0 then "41-50%"
else if r.\_value <= 60.0 then "51-60%"
else if r.\_value <= 70.0 then "61-70%"
else if r.\_value <= 80.0 then "71-80%"
else if r.\_value <= 90.0 then "81-90%"
else "91-100%"
|> group(columns: [“usage_category”])
|> count()
Memory: from(bucket: “telegraf”)
|> filter(fn: (r) =>
r.\_measurement == "mem" and
r.\_field == "used_percent"
|> last() // latest value per host
|> map(fn: (r) => ({
r with band:
if r.\_value <= 20.0 then "0–20%"
else if r.\_value <= 40.0 then "21–40%"
else if r.\_value <= 60.0 then "41–60%"
else if r.\_value <= 80.0 then "61–80%"
else "81–100%"
|> group(columns: [“band”])
|> count(column: “_value”) // count laptops in band
|> rename(columns: {_value: “laptops”})
|> keep(columns: [“band”, “laptops”])
Disk: data =
|> range(start: -1h)
|> filter(fn: (r) => r._measurement == “disk”)
|> filter(fn: (r) => r._field == “used_percent”)
|> filter(fn: (r) => r.fstype == “NTFS”)
|> filter(fn: (r) => r.device =~ /C:|D:/)
|> last()
|> keep(columns: [“host”, “_value”])
bands =
data
|> map(fn: (r) => ({
r with band:
else "81–100%"
bands
|> keep(columns: [“host”,“band”])
|> count(column: “host”)
|> rename(columns: {host: “laptops”})
|> keep(columns: [“band”,“laptops”])
