Grafana v8.1.2 (103f8fa094) on Debian GNU/Linux 10 (buster)
- What are you trying to achieve?
Using Variables for substitution of window sizes in my flux queries.
- How are you trying to achieve it?
I’ve set up two Variables in the Dashboard with different names and a standard value of “15s” on both of them
- What happened?
I’m getting an “expression request error” for the panel I configured.
The data should be downscaled in the way, that each point represents an interval of 15 seconds (the value of the variables)
- Can you copy/paste the configuration(s) that you are having problems with?
I’m using a flux query that looks like this:
from(bucket: "test_bucket")
|> filter(fn: (r) => r["datacenter"] == "5")
|> filter(fn: (r) => r["name"] == "exampleDevice")
|> window(every: ${windowSize}, period: ${windowPeriod})
|> mean()
|> duplicate(column: "_stop", as: "_time")
|> window(every: inf)
|> map(fn: (r) => ({ r with _measurement: r.name }))
If I hardcode the interval times, the query can be resolved by the influx Server, so the flux syntax is correct.
I have another dashboard, where this way of variable substitution is working without problems, but somehow it’s not working on this particular dashboard.
I looked into the request and I can see, that the substitution of the variables is not taking place (while the substitution in the other Dashboard I mentioned is present in the request body). Auto-Completion is correctly suggesting the variables btw, but they are simply not getting substituted by their values. Am I missing some sort of configuration I have to enable to use variables?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
This is a screencap of the request which was sent.
- Did you follow any online instructions? If so, what is the URL?
I tried various things; I compared the configurations of my two dashboards, I tried to rename my variables since the same variable names are used in my first dashboard, I tried to specify the type of my variables (${windowSize:text}), but nothing worked.
