[ i simplified my post]
I need to use Elapsed() function for a very simple data recording below
I do this query :
SELECT elapsed("state") FROM "QUASER"
the result is :
It’s what I want but I loose the state column.
doing
SELECT state, elapsed("state") FROM "QUASER"
doesn’t work.
I’m using an old version of influxDB (1.6.x)
I see in the docs that the 1st query should return what i want (time+elapsed(state)+state)
Is it a problem of version ?
If yes, can I do that without upgrading ?
thks
