How to Display Elapsed time
    Grafana 10.2 on windows
    To display elapsed time since a change occurred
    I’ve tried multiple different approaches including transformation but nothing seems to work
    There is no elapsed function that works and i can’t subtract time so i’m not sure how to approach it
Welcome
What datasource is this for
InfluxDb cloud
Hi @saxonbramble
Not sure if you ever found a solution (if yes, please post here), but if not, maybe this will help:
Have you run a query on your InfluxDB that determines that amount of elapsed time (hours, days, etc.) since the last timestamp? In addition, you would select your Unit in the Standard Options to be one of these:
Here are some other links from InfluxDB to get you started:
